error-might have been an "exception" error- too quick to correct the problem) about my linksys WLAN B utility after the PC booted up and was running. I did have a wireless connection though. I just could not use the WLAN utility. Tried to remove the utility and start all over (silly me). Tried to remove the utility thru its uninstall. It said it was removed but upon trying to reinstall it now says "The WLAN monitor and driver for the WMP11V4 have already been installed. blah, blah , blah...Run the uninstall program from from the "Wireless-B PCI adapter program group"".
panel, deleted ALL references from the Registry. Finally had to turn on WZC and let Windoze manage the wireless link for all to work.
under XP SP2. Is this true. The problem did seem to come into existence after SP2 was on for a while.
installed? The PC does not automatically connect to my wireless network any more. I must tell it to connect. Can this be corrected?
addresses. All works but want to connect automatically and not have Windoze WZC.
Have you tried removing the pci adapter in device manager. This should allow a reinstall.
