OS = Fedora Core 8, Router linksys wrt54G, adapter Asus WL-167g
I just cannot seem to crack it. I cannot receive an IP address via DHCP from a wireless router
- Router is up, other computers and a WII are seeing it fine and getting their IP addresses in range
- iwlist wlan0 scan shows the link at 48/100 strength
- ifconfig wlan0 shows link up
- module rt2500usb module automatically loads upon insertion of USB NIC
- OS reports NIC at Bus 3 Dev 2
- essid checked in conf and key correct. (I'd assume errors would come fast if they were incorrect). One thing though, is the key supposed to be encrypted as it states in the scan and if so where should this encrypted key be found?
OS reports NIC at ESSID checkedScript started on Sat 12 Jan 2008
08:52:33 AM EST cat ifcfg-wlan0DEVICE=wlan0 BOOTPROTO=dhcp #NETMASK=255.255.255.0 ONBOOT=yes TYPE=Wireless Mode=Managed ESSID=linksys_SES_60573 #WIRELESS=yes #WIRELESS_MODE=Managed #WIRELESS_ESSID=linksys_SES_60573 #WIRELESS_ENC_KEY=thisismypersonalkey WIRELESS_ENC_KEY=0b2e0beed5b93318d8a719dd20182ca76a43cc12f812c8aab6287e588b076bc8 #WIRELESS_RATE=54M
iwlist wlan0 scan
wlan0 Scan completed : Cell 01 - Address: 00:1C:10:A8:BD:EF ESSID:"linksys_SES_60573" Mode:Master Channel:6 Frequency:2.437 GHz (Channel 6) Quality=48/100 Signal level=-70 dBm Encryption key:on IE: WPA Version 1 Group Cipher : TKIP Pairwise Ciphers (1) : TKIP Authentication Suites (1) : PSK Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 6 Mb/s
12 Mb/s; 24 Mb/s; 36 Mb/s; 9 Mb/s; 18 Mb/s 48 Mb/s; 54 Mb/s Extra:tsf=000000637949bf67ifconfig wlan0 wlan0 Link encap:Ethernet HWaddr 00:15:F2:7B:FD:31 UP BROADCAST MULTICAST MTU:1500 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:0 (0.0 b) TX bytes:0 (0.0 b)
lsmod | grep rt2 rt2500usb 24641 0 rt2x00usb 12097 1 rt2500usb rt2x00lib 19009 2 rt2500usb,rt2x00usb rfkill 9169 1 rt2x00lib input_polldev 7369 1 rt2x00lib mac80211 131409 3 rc80211_simple,rt2x00usb,rt2x00lib crc_itu_t 6081 2 rt2x00lib,firewire_core
cat keys-wlan0 KEY=s:0b2e0beed5b93318d8a719dd20182ca76a43cc12f812c8aab6287e588b076bc8
wpa_passphrase linksys_SES_60573 thisismypersonalkey network={ ssid="linksys_SES_60573" #psk="thisismypersonalkey" psk=0b2e0beed5b93318d8a719dd20182ca76a43cc12f812c8aab6287e588b076bc8 }
lsusb Bus 001 Device 005: ID 0b05:1706 ASUSTek Computer, Inc. Bus 001 Device 001: ID 0000:0000 Bus 005 Device 001: ID 0000:0000 Bus 004 Device 001: ID 0000:0000 Bus 003 Device 002: ID 1241:1166 Belkin Bus 003 Device 001: ID 0000:0000 Bus 002 Device 003: ID 1509:9242 Bus 002 Device 002: ID 0430:0005 Sun Microsystems, Inc. Type 6 Keyboard Bus 002 Device 001: ID 0000:0000
dhclient wlan0 Internet Systems Consortium DHCP Client V3.0.6-Fedora Copyright 2004-2007 Internet Systems Consortium. All rights reserved. For info, please visit 'ISC DHCP'
