Help, i found a post about the same problem : how to delete a gateway.
In error, I connected and (apparently) set up a wireless connection using a USB wireless adapter ..... a gatewa is made that appeasr when i enable the wirelees connection.
I cannot disable it, getting the message: "IT is not possible to disable the connection at this time. This connection may be using one or more protocols that do not support Plug-and-Play, or it may have been initiated by another user or the system account"
I also cannot delete it under the Network Connections tab under the Control Panel: "You cannot delete a connection while it is busy connecting. Please disconnect or close the login property page and try again"
I do not know how to close these things, or even where they are. Please help!!!
Thanks simon
