Hi all! I cannot get internet access through my Belkin N1 Router. My LAN connection is perfectly fine, and works even when connected through the router, but I think there might have been an issue with some settings being changed. I cannot access 192.168.2.1 to change any of these settings. I have tried the reset button on the router to no avail and all of the connections. I am not sure what I can do. I have tried pinging 192.168.2.1 and I get 'Request timed out' so obviously it isn't connecting. What can I do to fix this? I have included what shows up when I type ipconfig /all
Microsoft Windows XP [Version 5.1.2600] (C) Copyright 1985-2001 Microsoft Corp.
Windows IP Configuration
Host Name . . . . . . . . . . . . : Home Primary Dns Suffix . . . . . . . : Node Type . . . . . . . . . . . . : Hybrid IP Routing Enabled. . . . . . . . : No WINS Proxy Enabled. . . . . . . . : No DNS Suffix Search List. . . . . . : hsd1.ut.comcast.net.
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . : hsd1.ut.comcast.net. Description . . . . . . . . . . . : Intel(R) PRO/1000 PL Network Connect ion Physical Address. . . . . . . . . : 00-12-3F-7D-68-EC Dhcp Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes IP Address. . . . . . . . . . . . : 67.182.251.112 Subnet Mask . . . . . . . . . . . : 255.255.254.0 Default Gateway . . . . . . . . . : 67.182.250.1 DHCP Server . . . . . . . . . . . : 68.87.66.21 DNS Servers . . . . . . . . . . . : 68.87.85.98
68.87.69.146 Lease Obtained. . . . . . . . . . : Monday, July 02, 2007 4:36:31 PM Lease Expires . . . . . . . . . . : Monday, July 02, 2007 6:24:48 PM------------------------------------------------------------------------ View this thread:
