When I was in college you could spot a nerd because he had a pocket protector and a rectangular box of punch cards under one arm. Pocket calculators came out later, cost around $400.00 and had nerds drooling over them. I was out of college when I saw my first HP calculator but I still had boxes of punch cards. ^_^
Yeah, that was the theory but it didn't quite work at Cal Poly Pomona in the late 1960's. Among other divisions, Cal Poly had an engineering skool and an ABM (agricultural business management) skool. One would assume that the engineering students carried slide rules and punched cards, and the ABM students looked like TV cowboys. Nope. The engineering students wanted to look like cowboys and wore boots, jeans, flannel, but not the hat. The ABM students wore suits, ties, hats, and carried briefcases. There was also a skool of environmental design, which true to the stereotype, everyone looked like hippies. I tried to make sense of it at the time, and gave up.
Incidentally, it took me about 10 years to work my way through all the punched card decks I had accumulated and used mostly as scratch paper. I didn't make the same mistake with paper tape, which I converted to floppy and burned the tapes.
My first calculator was an analog computer that I built into a brief case. There were several 10 turn pots to input the numbers, and a big mirrored meter to read the output. Basically, an electronic implementation of a slide rule.
When I graduated from college, I could throw everything I owned into my pickup truck and drive off into the sunset (and actually did that a few times). If I tried that today, it would take at least two large moving vans and a project manager.
Yeah, but you can still see garbage if there are any intermod mixes.
It doesn't take much mixing to produce inband interference. For example: (2 * Ch_6) - Ch_11 = Ch_1 (2 * 2435) - 2460 = 2410 Mhz There are plenty of other possible mixes all of which produce interference. With a 16-22 MHz wide signal, producing intermod junk on any channel is all too easy. All it takes is two STRONG inband signals and you get a third signal for free. This is fairly easy to do with outdoor systems, where one years a fairly large number of possible interference sources, many of which can be rather strong. With the limited dynamic range of the typical Wi-Fi receiver, all it takes is something that runs the receiver out of dynamic range, and mixing takes place. Mixing can also happen in the transmitter, where a strong nearby transmitter signal, goes down the antenna, mixes in the xmitter PA stage, gets amplified, and rebroadcast by the PA and antenna.
If you feel ambitious, you can see the effect with two access points, two laptops, and a spectrum analyzer or possibly signal sniffer. Set the two access points Ch 6 and Ch 11. Connect to each one with the laptops and move some streaming data. Large packet pings to the access point IP will probably also work. Watch the display on the spectrum analyzer or signal sniffer. You'll see strong signals on Ch
6 and Ch 11. You'll also see a rather weak signal on Ch 1 when the access points are close together.
I haven't done this test in many years, so I don't know if todays access points are better or worse. I guess I should try it, but I'm busy (or lazy) until maybe next year.
Punch cards were for the CS weenies. ;-) The real nerds had slip-stick scabbards hanging from their belts (I carried mine with my books). Over my senior year, the slip-sticks were being replaced by calculators (and holsters for scabbards ;-). I bought an HP, and yes, it was $400 (about 10-weeks gross pay).
Here in Alabamastan we actually have a state college, The University of Auburn, which is both the premier agricultural and engineering school. I traveled to Auburn one year to visit some friends and drove past "The Swine Research Unit". The smell could gag a maggot but the pigs were happy. In the mid 1960's at The University of Alabama, I started playing with and learning a tiny bit of Basic and Fortran in order to play with the Univac which was on its way out and the new IBM 360/50 RAX system which was replacing it. Kids these days have no idea how user friendly computers are now compared to what I started playing with like the analog computer at my school but I really believe computers were more fun all those years ago. Now they're tools, not so exclusive anymore and any kids gaming computer has much more computing power than what was considered a super computer at one time. ^_^
I can't disagree with Jeff's situation, only I don't have the new ladylove. I have all the "stuff". It gets to a point where you can't find that widget you built way back in the early 80s.
Huh? Wow. I had never heard of that, for antennas & reflectors. Hmmm... I've seen it on the inside of monitors I've disassembled, especially the white ones (where the inside is a scratchy gray painted color).
Hmmmmm..... so what would I paint?
I guess I'd paint the backside of the Rocketdish reflector. Would I also paint the outside of the Rocket M2 radio unit? I guess I could also paint the CAT5 cable coming into the rocket.
Oooops. I just realized, I did NOT use shielded cable for my cat5. I used indoor plenum stuff. I wonder if shielded cable would have made a difference?
I'm still amazed that you saw that, lurking inside the graphs!
You must have eyes like an eagle, because I had not seen it (until you pointed it out).
Although, for the life of me, I can't determine the *source* of that channel 9 interference since nothing inside the house or nearby seems to have a strong enough signal to register as channel 9 WiFi...
For example, here is a scan on my laptop for access points:
Nothing is on channel 9.
Here is a scan of the access points from my radio:
So, I do agree with you that there is a good amount of channel
9 interference; but I must conclude the source of that noise is distant (but clearly in the path of the radio).
My Dad, bless his heart, taught me how to use a slide rule when I was in high school trig class. His was bamboo and white, as I remember it. He bought me a smaller one, and I cherished it. I hope I still have it, but, I've moved a half dozen times since so it's somewhere.
Hi, You guys are little bit behind me, when I was into it during and after school, computers were called electronic calculator as such containing vacuum tubes, mechanical relays.. from there transistors, small scale IC all the way into nanotech which is now. I used to use blank punch card with columms and rows all half pre-punched so we can push the confetti out to make holes where we want to do Fortran programming. If you drop the card deck by accident, you have to resort one by one to make them in proper order before you can have it read. Also remember 51 column card? Credit card receipts were 51 column card size which could be read after they are punched by key punch operators(girls) reading the amount written and imprinted account number. My Ham radio hobby was from the '50s, licensed in '60. Hold Extra U.S., Advanced/Digital Canadian, First class Korean licenses. Right now I am busy resetting up our HT system into 7.1 with new AV receiver and speakers. Better be done before X-mas.
We must pass our knowledge and skills on to a younger generation because they are being lost. If our modern society crashed, most people would be helpless because they have no idea how older simpler technology works. Perhaps Boy Scouts could help people survive? o_O
Ditto. Despite the briefcase analog computer contrivance, the grunt work was done with a 6" K&E. The one in the photo is what I used a half century ago. (Hmm... why am I suddenly feeling old?) I still use a slide rule for doing gear ratios. I also give occasional demos of the slide rule to kids that have never seen one. Incidentally, I give a song and dance on using a nautical sextant in a few minutes... oops, I'm late.
Yeah, sorta. These daze, all the wi-fi chips are digital. The purpose of the RX AGC to make sure the input A/D converter uses all the available bits for maximum dynamic range (and lowest digital noise). Therefore the AGC stage is usually the first device after the T/R switch.
The big question is where is the detector that tells the AGC to reduce gain. Usually, it's right after the A/D converter, inside the CPU. It checks for the peak digitized signal level. If it's above some threshold, the AGC turns down the front end gain until the level is constant.
