After a lot of problems I'm connected via wireless to my pc. I'm using talktalk as the isp and a belkin modem/router. I know that I'm connected as i've got the icon in the bottom right hand corner and also I can send/receive emails via outlook. However, I cant use Internet Explorer. I've made sure that on IE connections it says do not dial. I just get the standard screen message error.
Any ideas what I should do? Would appreciate any help.
Many thanks Peter
