snipped-for-privacy@gmail.com wrote in news: snipped-for-privacy@4ax.com:
So if you just leave the router on which you should do and issue the IPconfig /release and renew on the machine everything is OKAY DOKEY with the connection, then I suggest that you just leave the router on 24/7 365 like most people do of companies that use routers and forget about it.
Duane :)
