Hi all, I have a Netgear WG311T PCI Adapter and pick up about 9 different networks with it. However I can only connect to the one G network of the bunch. Signal strength is about the same for but generally low for each (45-56%) in the Netgear Software. Any time I try to connect to any of the B APs I get the "Wireless Network Unavailable" message. I have Auto-Config in Windows turned off and the 802.11B in Netgear's "Advanced Settings" checked.
I have SP 1 but note SP 2 installed. I built an antenna out of a Pringles can but the stock antenna or the external yield the same result except I pick up a few more of them with the Yagi.
If anyone can tell me what the problem is or where to get more information on what to do then I would appreciate it. TIA
