Can't connect to configure my Netgear WG602 access point
Threaded View
For the life of me, I can't make a successful cable connection between
my computer and my Negear access point to make changes to the settings.
I've set the IP & subnet mask on the PC as specified by the manual, and
I've tried it from several computers. Whenever I go to the IP address
of the access point, the connection simply times out. Help!
Re: Can't connect to configure my Netgear WG602 access point
wrote:
Are you connecting the WG602 directly to the computers or via a
hub/switch? If directly then you will probably need a crossover cable.
WG602 v1, v2 or v3 ?
Some possibilities.
1.  Turn OFF the wireless on your computah.  Some laptops (Toshiblah)
with autoswitching between wireless and wired connections will give
the wireless connection priority.
2.  http://192.168.0.210 Has this been changed from the default?  If
you don't remember the IP address, you may need to reset the WG602 to
defaults and start over with the setup using the default.
3.  Have you assigned a static IP address to your computah?  The WG602
does not have a DHCP server and therefore cannot assign an IP address
to your computah.  This must be done manually.  See install guide.
4.  Cable polarity.  Do the lights on both the access point and the
ethernet port light up when you shove in the cable?  If not, you MIGHT
need a cross over ethernet cable.
5.  Where are you plugging in the ethernet cable?  Into the access
point should work, but if you have other devices (i.e. router) sitting
on an ethernet switch, you may have duplicate IP addresses.  Keep it
simple and just connect the access point?
6.  If all else fails, and only in final desperation, after you've
tried everything else possible, follow the proceedure in the intall
guide:
  http://kbserver.netgear.com/products/WG602.asp
(select correct version)
  ftp://downloads.netgear.com/files/wg602v3_install_guide.pdf
Jeff Liebermann     jeffl@comix.santa-cruz.ca.us
150 Felker St #D    http://www.LearnByDestroying.com
Santa Cruz CA 95060 http://802.11junk.com
Skype: JeffLiebermann     AE6KS    831-336-2558
Argh.  That should be http://192.168.0.227 for the WG602.
These are great suggestions. I will try them tonight and let you how it
goes. Thanks!!!
Site Timeline
