A wireless question:
Can old wireless NICs with old drivers/softwares connect securely with WPA? I know WEP (128-bit) will work. I have this old Netgear wireless PCMCIA card (3 years old? 802.11a?) that was used in Windows 98 SE, and was wondering if I can use it with WPA encryption? WEP does work.
Is there a special rule how security protocols work for wireless setups? I have never seen any WPA enabled (does recognize WEP) with client hotspot/AP finders. Maybe it doesn't know WPA?
Thank you in advance. :)
