Hi, hoping someone can help me. All of a sudden I was unable to get to a series of websites all on the same IP. They are all my websites. I called the host provider and they had no problems. In fact I could get to the sites by using proxify. But aside from that I couldn't even ping them.
Just to see if it was my equipment for some reason, I took the dlink
524 (I think) out of the middle and hooked my cable modem directly to the PC. I could then get to the sites. I let my router "rest" for a good 30 minutes. Put it back in the picture and the sites were blocked. I am able to repeat this at will.How could my router cause a problem like this? I have made no changes. I'm not even using my main PC on a wireless connection. It's using the wired router ports. Just don't see how the router could cause problems on one set of website (all on the same box and IP) out there. Sounds like a ISP problem, but it goes away when the router is missing in my topology.
Thanks for any help.
