I installed my Linksys router WRT54GS on my pc..........to be honest it seemed to install fine, but I had problems trying to set up the security.... So i restarted it all...........I give the network a new name MYPEECEE and set up the security fine........
Now...everything seems fine on main PC but when the laptops are in use, they detect both networks ...i.e. the first one called LINKSYS which is marked Unsecure.........and also the correct one called MYPEECEE and i had to input the code for them to work. Can anyone tell me how to remove the first Linksys one, or at least put a bit of security on it...
Is it doing any damage being there, except at the moment being totally free and accessible to all around- A bit on the dangerous side.
I tried logging into the Linksys one and it did it fine......then i logged back to secured one.......im desperate to secure things up properly here.
Thanks Dave
