I decided to upgrade my old wireless network, so I went out and purchased an "Enhanced G" router (a Dynex DX-WEGRTR). I also have a Dynex PCI adapter (DX-EBDTC) and a Buffalo Technology WLI-U2-KG125S USB adapter.
The PCI adapter is installed in my desktop (Windows 2003), and I use the Buffalo USB adapter in my laptop (Windows XP).
This all is working pretty well, and both adapters do run at 54Mbps, but despite lots of tweaking of both the router settings and the settings at the PC end, I cannot get either the PCI adapter or the USB adapter to show up as 125Mbps in the Systray icon. Both show "Excellent" signal strength, and I have the router only approx. 20' away.
I also noticed that in the Advanced Configuration for both the PCI adapter and the USB adapter, the highest "Rate" setting is 54Mbps and "Best Rate".
So, I'm curious: Should I actually be able to get these to run at, at display, 125Mbps? If so, any ideas about what changes I need to make?
Thanks, Jim
