hi all
had enough with my linksys wrk54g, the constant re setting is a pain, so im looking for a better router,
any suggestions pls
Ehi all
any suggestions pls
E
My office WRT54G v3.0 seems quite stable. Current uptime is 18 days: |
Now, if you want the best, and don't care about the cost, I just checked the uptime on a customers Sonicwall TZ170 SP wireless: |
Another system uses a Cisco AIR-AP1231 access point that was showing about 40 days before I rebooted it last week. |
I am happy with my buffalo Turbo.
Bob
Agreed, I ripped out all my d-link stuff and replaced 'em with Buffalo, been solid ever since.
Jeff Liebermann wrote: See upper right after "Time:")
DD-WRT-22 has 112 days of uptime, but with very little traffic through it. I use it as a WAP downstream of my ISP's supplied D-Link
mike
There is a huge difference between the current WRT54G V.5 and your WRT54g V3. The V.5 is a much cheaper routher with less memory and a totally different operating system. If someone is looking for a router that is roughly equivalant to the V.3, they need to purchase the WRT54GL. The L stands for Linux which was the operating system on all WRT54Gs until they came out with the V5. Problems with the V5 are well documented.
Yep, sorta. The WRT54G v4 and the WRT54GL are identical hardware as the FCC ID numbers are the same.
The V5 routers *CAN* run alternative firmware. See: |
You are correct that you can run the mini version of dd-wrt on the v5, but the firmware change on the V5 requires a jtag cable. The operating charactersistics of the verssion 5 are much different. I own both. The V5 is much more prone to lockups, runs much hotter. Trying to flash the V5 with dd-wrt is a challenge, with many users bricking their router in the attempt.
The Ghost of Thomas Jefferson hath wroth:
The WRT54G v5 router requires the -MICRO- version of DD-WRT, not the mini version.
Parallel port: |
You're being generous. I think the V5 is an piece of junk. |
Yep. I haven't attempted it myself, but I know of two local hackers that have done it successfully. It's probably more than the average home user is will (or should) attempt. But, it is possible to do successfully.
What's the consensus on an Actiontec Model GT704.WG Wireless DSL Gateway? I finally gave up on my Linksys WAG54G and trashed it. I bought an Actiontec at CompUSA yesterday and set it up. It was very easy to se up on my administrator desktop computer, but I am having some difficulty getting the laptop and kitchen desktop computers to function through the Wi-Fi. They both acknowledge the Wi-Fi, and seem to have a firm, high speed connection, but neither of them can "find the internet." I must have hidden the darned thing while going through the setup for the Gateway, but I can't figure out what setting(s) I have wrong.
Gordon
On Thu, 22 Jun 2006 21:06:36 GMT, Jeff Liebermann wrote: : On Thu, 22 Jun 2006 06:12:53 -0400, The Ghost of Thomas Jefferson : wrote: : : >There is a huge difference between the current WRT54G V.5 and your : >WRT54g V3. The V.5 is a much cheaper routher with less memory and a : >totally different operating system. If someone is looking for a router : >that is roughly equivalant to the V.3, they need to purchase the : >WRT54GL. The L stands for Linux which was the operating system on all : >WRT54Gs until they came out with the V5. Problems with the V5 are well : >documented. : : Yep, sorta. The WRT54G v4 and the WRT54GL are identical hardware as : the FCC ID numbers are the same.
If you upgrade a WRT54G v2 to the latest firmware available on the Linksys site, it subsequently identifies itself as a WRT54GL.
