Greetings folks, I recently came in here to see if others were having the same problems with this card. It seems some are...
I recently purchased this card to compliment my notebook merely for asethetics. I also have a netgear wg511 but opted to use that for a different notebook that I'm using at home now for work purposes. My personal notebook is black so I really took a liking to the slightly shorter and less obtrusive wpc54gs. My router is a WGR-614. After playing with the linksys card further, I was intrigued by the advanced driver configurations that can be made (power output, wme, fast power save mode etc.). Needless to say any combination of driver configuration yields a card that loves to drop connections frequently, and simply can't hang with the wg511 on distance, overcoming interference, and bandwidth. I live in a 900 foot apartment space and using the wg511 right now, I have a 95% signal rate and 54Mbps connection link right now. In the very same position, I'm lucky if I get 45% signal strength with the linksys, actually even going down to
1Mb and dropping connection totally, not even able to reconnect. Since buying the card, I've lost connections more times than I've blink. In addition I round the wireless utility manager lousy. It constantly shows no connection to the internet (even when there is one) making it inaccurate and therefore partly useless.I just wanted to know if any here have experienced similiar distaste for this card? I'll be taking it back to Wal-Mart 1st thing tommorrow. Since I still need a card, I was thinking of the netgear wg511 v2 but after reading about the newer chipset from others here, it seems that might be a disappoint as opposed to the v1 too.
Any recommendations on another really good card (as I've found the wg511 v1 to be) preferably in a black color?
Regards
