Interesting problem. Using the satori 4.x firmware on the Linksys wrt54g and putting it into client mode, the pc connected to it worked fine with the wgt624 as the AP (after a lot of fiddling with the settings based on other forum/usenet posts). However, as soon as I tried WPA (tkip, since that's all netgear supports on this router, no aes) and wep (128) using the same passphrases on the wpa or the same key on the wep, they wouldn't connect anymore. Is this a broken router (its a v1 on the wrt), or will they not connect using wep or wpa? Thanks!
- posted
19 years ago
