I currently have two separate workgroup networks in 2 rooms.
Each room has 3 pcs connected to an ethernet switch and they are peer to peer.
Very simple setup.
The rooms are about 80 feet apart.
Id like to merge them into one network using Wireless Access Points.
My belief is that I simply buy 2 APs from the same manufacturer and give them the same SSID.
I plonk one in each room and get the clients in each room to associate with the AP in that room.
The APs are then switched onto bridged mode and they automatically forward traffic from one room/network to the other (all different IPs of course).
Is this correct ?
