Bridge/workgroup bridge scenario and channels
I have been asked to provide a point - point wireless link between a site with an adequate WAN connection and one with no WAN connection then access from three small wired networks.
I have access to the following equipment ..
2 X Cisco 350 Wireless Bridges 5 X Cisco 1231 Access Points
I propose the follwing scenario ... a Root Bridge (Cisco 350) on the WAN site, a Non Root Bridge on the non WAN site (Cisco 350) (for the link) and three 1200 Access Points (in workgroup bridge mode).
I will use the two 350's to set up the point - point link back to the WAN connection and use the 1231's in workgroup bridge mode as the link back to the wireless network for the 3 wired networks.
The question I have is regarding the channels to use, I understand that both the 350 bridges need to be on the same channel and have assigned them channel 1, but I can find no documentation to indicate which channels I should have the workgroup bridges on.
I realise that as I am using 802.11b devices I should only be using channels 1, 6 and 11 so I don't have much room for manoeuvre and would appreciate any advice.
Drop the ZZZ to reply
Cheers ...
Chris_D
Chris,
Am I following your proposed topology correctly? I have it like this:
[rootBR350]~~~[nonrootBR350]~~~[wgb1] ~~~[wgb2] ~~~[wgb3]
I.e. there is no wired infrastructure at all?
In that case, since nonrootBR350 has only one radio, and all of your equipment must connect to nonrootBR350, then all equipment must be set to the same channel.
There is no significant performance difference between channels 1, 6, 11, unless your site has some specific interference pattern.
Regards,
Aaron
Aaron Leonard
Thanks for that Aaron,
I have a test scenario set up and all seems to be well although my workgroup bridges only seemed to want to connect to the root bridge.
I have to set up a second ssid on the non root bridge for the workgroup bridges to associate to and this seems to do the job.
Cheers ...
Chris_D
OK cool.
I believe that you should be able to configure the WGBs preferentially to associate with the nonroot bridge rather than with the root bridge, by using the "parent" command under the radio interface. (This was designed for use in repeater rather than WGB mode, but I think it should work in WGB mode too.)
Regards,
Aaron
Aaron Leonard
