Hello.
I have a public hotspot that I want to access using my D-Link DWL-2000AP+ but Ive been unable to do it! The L-Link is set up as wireless client and when I search for available wireless networks it finds the hotspot with SSID "802_11g" on chanel 6 and it parses the MAC address from him.
I know that the hotspot is DHCP enabled in the range 10.0.0.X and gives as gateway the IP 10.0.0.254 and DNS 192.168.3.5
The D-Link is configured with DHCP disabled and IP 192.168.1.1 but I'm unable to set the gateway as 10.0.0.254!!! I don't want and I can't put the D-Link with a IP in the range 10.0.0.X as I don't want to conflict with the hotspot network!
In the computer side, I've put a IP like 192.168.1.20 and gateway 10.0.0.254 but nothing! The only way to access to the hotspot network was with the D-Link with IP 10.0.0.10 and the computer with IP 10.0.0.20 but this will use 2 IP's on the public network and later it will use maybe more as I will put my Asus WL-500g connected to the D-Link so that the Asus will make the wireless transmission to my network!
What config should I make in the D-Link side, keeping in mind that I need to have a IP range different from the one of the public network?
Thanks, Miguel
