Apologies in advance if this has been asked/answered before but I haven't found it.
I'm using an Engenius/Senao 3220 on my boat, configured as a bridge, to access shore based access points. It is set up with an IP address of 192.168.1.3 which is used to access its internal configuration menus via http, web browser, etc.
I ran into an interesting issue this morning accessing a commercial access point which redirects all http traffic to its own sign on page. Once the bridge has been reconfigured with the SSID of this site, and has connected, I can no longer access anything else which means that I am prevented from further reconfiguration to switch the SSID back to some other access point. I thought originally that this redirection was being done with a proxy server which I could avoid by changing browser settings but that is not the case.
I was able to work around the issue by disconnecting the antenna to the 3220 which prevented connection to the commercial site and allowed me back into the internal set up pages. Although this works I'd prefer a more elegant solution which would prevent the redirection of
192.168.1.3. Sometime in the future I may remount the 3220 on a higher point which may make it difficult to access the antenna connections.Any suggestions?
