pc_A con wifi verso la rete locale + interfaccia_lan
pc_B con interfaccia_lan
vorrei usare B e passare attraverso A per usare la rete locale anche da B, =E8 possibile?
vorrei usare B e passare attraverso A per usare la rete locale anche da B, è possibile?
Non losso, parlo ingelsi force ?
in english: I would like to create a bridge in WinXP. I've a pc with 2 interfaces: lan and wifi. How can I do a bridge?
hold down ctrl and click both interfaces, right click "add to bridge"
it's not so easy. It seems that it doesn't work. have you ever try this?
Yes it works but you're really not saying what you did and what didn't work. Was it that the bridge didn't work or that you couldn't get the bridge to configure?
what didn't work?
David.
It's pretty easy. I have a pc with 2 interfaces. I activate the BRIDGE on this pc.
But
- How I configure the pc with the bridge?
- what ip I put in the pc on the lan?
- why the pc with the bridge activated can't navigate on the web anymore?
