Not always the brick walls.. Usually when they brick a wall, they put a metal screen up with straps that go between the bricks (and are mortared in) to keep the wall from falling.. It's usually the metal screen backing that may be causing the problems. If not too big they make passive repeaters (cheap, no power needed), one end goes in an open area, and the other in the dead spot. Be real real careful, many "snake oil" products are out there that don't work. Learn about smoothing out WiFi access at
