I have a WAN in a 4 story, house but the wifi signal only reaches one half (the rear end) of the house. The current setup is: telephone plug with ADSL signal on the 3rd floor rear -> cable modem -> SMC wireless router. Since the signal seems unreliable the two uppper (3rd and 4th floor) PCs are hardwired to the router via ethernet. a laptop on the 1st and 2nd floor connects via wifi. The problem is the range is limited and the performance shakey.
can I modify the setup to insert a cheap wired-only router between the modem and the wifi router? If so I would get better wifi signal acrosss floors 2 and 1.
so I would wind up with: telephone plug -> wired-only router (to which the 2 box PCs would connect via ethernet) -> long extension ethernet from 3rd floor to second floor where a wifi router would serve floors
2 and 1?otherwise how can I do this? give wired service to the upper floor PCs and have a wireless access point lower down.
many thanks
Peter Stock
