have a d-link wireless router. have a laptop and want to use a bluetooth usb adapter. Is this possible and how do I connect to the router if possible. Does bluetooth work on a particular channel as it does not seem configurable.
Many Thanks
Bazza
Many Thanks
Bazza
If you already have a wap/router, consider one of these
Plugs into your router ethernet, works as a second seperate AP, and give BT access to the network.....
You can use a BT dongle on a laptop to access the whole network (I did before I found this), but got rid of those, got one of these, and love it...
If you are worried about conflict, the older BT USB dongles do conflict, but the newer ones don't... (there was a post about this exact thing a while ago (IE BT conflict with WiFi wap/router, but all I recall was something about BT 1.0 and 1.2 (Think those where the numbers, original answer was from jeff, maybe he'll answer again, or you should be able to google it)
