Hello all,
Hope someone can help. I'm using two 54g PCI cards to connect two PCs in ad hoc mode. I use a software router on the PC connected to the net and share the connection with the other. All worked smoothly until I had to move one of the PCs (further away). Now throughput speeds have dropped dramatically and the network occasionally drops out altogether.
My cards are Belkin. I notice that they sell a replacement antenna that is designed to sit on the desktop and extend range. Do you think this will work?
Thanks.
