Can anyone point me to the direction for the BEST Long Range Wireless ard? - Meaning best signal and throughput over the longest distance.
Thanks.
Thanks.
I recommend the Netgear WG511 or the Netgear WG511T card. Both have exceptional range.
stuck a hypertech off eBay blade Omni antenna on my laptops cpx gPC Card(mc conn), range & wall poke went up considerably, even found another neighbor(Cornhusker 00:12:17:31:c6:01 # Cisco-Linksys, LLC). cheap to do too.
