What card has the best range and allows you easily integrate an external antenna?
Thank you ! Tom
Thank you ! Tom
I think I could supply less information in such a question, but I would need to work at it. So, we try the interrogation method of prying loose the necessary information to answer your question.
first part: difficult to answer - .. depends second part: AFAIK there are still no 802.11a Cards with external antennas, cause of some FCC regulations.
There are 11a-APs with external Antennas from Lancom and Cisco has anounced a AP with external Antennas. But i know no PC-Card (there is no
11a-PCMCIA) with external Antenna.Greetings Pitz
------------ And now a word from our sponsor --------------------- For a secure high performance FTP using SSL/TLS encryption upgrade to SurgeFTP
---- See
