Belking G to N problem
I've setup a new wireless install as follows:
Belkin Pre N router, Belkin "High Speed" 11g desktop NIC # F5D7001, and a D-Link NIK running 11b. One computer is hard wired. All OS's are WinXP Pro with all updates including sp2. 4 machines total.
My problem is on the machine running the 11g NIC I have a user that is not an administrator. When logged in as a user the NIC is disabled, that is the "radio" is off and I can't turn it on so there's no connection. If I make that user an administrator all is well.
The machine with D-Link card works fine.
I've called Belkin and they indicated that they've seen this once before and it went to second level support then I got cut off. Will call tomarrow.
Any thoughts?
Unless you folks have something I'll post their solution when I get it.
Don W.
Well I talked to Belkin and they say they say there's nothing wrong with the card. Instead, either there's a service that's running that shouldn't, or one that's not running that should.
Any thought on what that service might be?
Don
Don W.
