Hi, I have a Belkin F5D7230-4 wireless router and I am trying to set it up in my house with CAT 5 outlets in several rooms (one outlet per room). My dsl modem is in the basement and is connected to the CAT5 infrastructure in the house. The Belkin has a single WAN and several LAN ports and I want to place it in my office room. Since I have just one CAT5 outlet in this room, if I connect the outlet to the WAN port of the Belkin, then my wireless devices work fine. But a wired device connected directly to the CAT5 outlet in another room won't work since it is not connected to the LAN part of the Belkin router. I tried to connect the LAN port of the Belkin to the wall outlet in the office and then tried to use another network cable to connect the WAN port of the Belkin directly to one of the remaining LAN ports of the Belkin. This way, the Belkin can reach the dsl modem as well other computers on my CAT5 infrastructure. However, this doesn't seem to work either and I have routing problems and intermittent connections from some of my desktops (connected to the CAT5 outlets in other rooms) that are unable to reach the Belkin router with a ping all the time. I think this is a routing problem overall since the Belkin router uses the same LAN and WAN mac addresses. I would appreciate it if someone could tell me the best way to set up the Belkin router. All of my computers run windows xp. Thanks, Vasi
- posted
17 years ago
