Trying different routers out, looking for a soho combination that works well.
Belkin F5D7230-4 works well except that at times all settings will be lost and the wireless side of it stops working. For example, one day your speed is great, amazing, can transfer 5 gbs wireless without issue, one would say the connection is solid. Then one day, your new laptop wireless cards (both Intel's) gets a "network out of range" message from the Intel ProSet software and the router must be reset and all information entered from scratch in order to connect to it again. Using the latest router firmware and network software on the cards.
The network card works because I can connect to other access points without any problem.
Is it the Belkin product?
Smith
