tried to setup a 4 port belkin wireless router as an access point only, to connect to another wireless router, it took the change, changed its IP to 198.168.2.254 but now I cant see the belkin at all via the maintenance page address
tried the reset at the back but no luck, is there any way to get the danged thing back to factory default if you cant see the maintenance screen?
fwiw, this Belkin unit has been a real headache,
