I just got a Belkin DSL Router (F5D7231-4) which I got as-is, therefore did not come with a power adaptor. I have an adjustable voltage power adaptor, and I know the router uses 5volt, but would like to know if anyone with any Belkin routers out there could tell me if the tip is negative or positive, by checking your adaptor.
Thank you so much for your help in advance!
Tom M
