I've just brought my wireless router back from work and tried to set it up at home with very limited success.
The first problem was remembering the login password. I blatantly couldn't remember it so I thought it would be clever to reset to the factory default settings and start over.
The problem is: whatever I change in any of the sections in the router config, when I click "apply changes" it spews out some rubbish about "ap0 no private ioctls" and "segmentation fault". It's done it so far when I try to change the admin password and when I try to enable security. Then when I return to these sections they haven't changed at all.
I've updated the firmware from 2.01.13 to 2.01.19 and the only difference I can see is the ability to choose the interface language on the home screen. The above problem still remains. :\\
Any help appreciated, the belkin site doesn't seem to be that helpful and googling hasn't helped me massively.
[image:The most helpful comment I've heard so far is "ooh segmentation fault, that doesn't look very good". :(
