Hello Saturday I bought a Belkin N series router F5D8233, my last router was also a Belkin which worked fine but like all good things as soon as the warranty runs out it stops working (strange that!!) anyway, the new one works fine, set up was easy etc, but I have a little problem, My PC is cable wired to it, but the rest of the home is wireless, my computer connects straight away when I turn the PC on, the Laptop and the kids PC's don't, I have to repair the connection using Windows XP repair tool everytime they turn on, if not they get limited connectivity. Windows says that the ip address needs renewing everytime the PC's are turned on, but only the wireless ones.
Anyone know what the problem is?
All the PC's use windows XP SP2, all te network cards are realtek, they all worked fine with the last router.
Thanks
Gordon
