I have a Belkin wireless G router model F5D7230-4 that has recently started disconnecting when left idle for 10-15 mins. I have read other posts about changing the idle time but cannot find where i check to see what its currently set at to see if that is the cause of the disconnection. I have never altered this setting since i started using the router so im not convinced this is the cause. I have updated the firmware which again has not solved the problem. To rectify the problem i have to disconnect the power and reconnect it.
Any help would be appreciated
thanks
