Belkin Cable/DSL Gateway Router 802.11b need the best Wireless card
Threaded View
I have a Belkin Cable/DSL Gateway Router 802.11b. 3 PCs and a new Dell
P4 Notebook.
What  Wireless card should I buy for the Dell Notebook? Is it
necessary to use a Belkin wireless card that is  802.11b?
Re: Belkin Cable/DSL Gateway Router 802.11b need the best Wireless card
>P4 Notebook.
Another severe case of "fear of numbers".  Any reason why you didn't
supply model numbers, or do you believe that Belkin and Dell only make
one model router and laptop?
No, you don't need to buy everything from one manufactory.  That's
what standards like 802.11b are all about.  Anything with 802.11b
scribbled on the package should work.
If your "new" Dell P4 Notebook really is new, then one of the stock
wireless card would probably be the "best" choice.  See:
http://www1.us.dell.com/content/learnmore/learnmore.aspx?c=us&l=en&s=gen&~id=dfamilywireless&~line=notebooks&~mode=popup&~series=latit&~tab=other
You can get any of these for $20-$45 on eBay or from Dell.  Make sure
your "new" Dell P4 has a place to insert it (inside) and that it has
the corresponding antenna connector from the display section, nearby.
Jeff Liebermann    jeffl@comix.santa-cruz.ca.us
150 Felker St #D   http://www.LearnByDestroying.com
Santa Cruz CA 95060    AE6KS  831-336-2558
You can buy a 802.11b card or an 802.11G card, If you think you might
upgrade your router to a G later I would buy a G card. G will talk to B and
G.  I would buy whatever brand your local stores carry, give it a try and if
it dont work take it back,        A "WiFi certified" card should work.
> P4 Notebook.
I agree that any wifi certified card 'should' work.
But if possible, I think buying from the same company makes life easier,
particularly for the less experienced.  When you call for tech support when
you have a DLink router and a Belkin card, which one do you call - and it's
always the other one that is causing the problem.
And some features on some products only work with both components from the
same company.  Like super G etc.
> and
> if
>> P4 Notebook.
Site Timeline
