I have a belkin F5D7230-4 router. every 4 - 6 minutes it disconnects and reconnects on its own. tried other channels did not help. Any suggestions? using128 bit wep and mac address filtering for security
- posted
18 years ago
I believe that the Win XP Wireless Zero Configuration has an authentication mode. Make sure it's off.
Hope this helps.
Harvey
I'll assume Windoze XP for the client. If you want useful help, try supplying all your hardware and software names and versions. Otherwise, my guess is:
thx, will try it and post my observations.
thx will try it and post my observations
well, the wireless zero config seems to have done the Job. I do not get disconnected any more.. thanks for your recommendations..
