I recently installed a friend's computer with a Belkin 54g PCI wlan
adapter. Because the computer had a 56k modem connection before, no
updates were installed on the standard Windows XP home edition.
After the installation of the PCI card, everything seemed to work
fine, so I decided to install SP2. After the upgrade, the card is still
being recognized and the driver even finds the network I configured,
but is really really slow. It looks like the connection is active for
about 10 seconds, then stops (without notifying me about a disabled or
unavailable connectins) for about a minute. Then it seems to be back up
again for a couple of seconds and then down for a minute.
I downloaded and installed the latest driver from the Belkin website,
but no results. Because I wanted to make sure the network itself was
ok, I tested it with my laptop (which has a linksys card) and that
seemed to work fine.
Anyone got an idea?
