BBSID versus SSID
Threaded View
Hi there,
I have a wireless router that has 2 BBSIDs on one SSID. I.e. when I connect
I see two identical wireless networks, except for the BBSID. One of the
networks has a reception of 50%, the other 35%. My network automatically
connects to the 50% network, but this network is very slow. I want my
network card to (statically) connect to the 35% one. Is there some way I can
do this (forced)?
Card: ralink / raconfig2500 2.3.0.0.
anyone pulled this of before?
thx, in advanced
Seansan
Re: BBSID versus SSID
On Sun, 9 Jan 2005 12:18:35 +0100, in alt.internet.wireless , "Seansan"
>Hi there,
Sounds pretty unlikely - two BSSIDs would imply two different sets of
hardware.
>I.e. when I connect
sounds more like two identical routers in adjacent houses, with the same
default ssid.
>I want my
>do this (forced)?
Change your router's SSID to something unique to you, and tell your Os to
use that as a preferred network. In XP you do this in the wireless config
settings.
Mark McIntyre
CLC FAQ <http://www.eskimo.com/~scs/C-faq/top.html>
CLC readme: <http://www.ungerhu.com/jxh/clc.welcome.txt>
----== Posted via Newsfeeds.Com - Unlimited-Uncensored-Secure Usenet News==----
http://www.newsfeeds.com  The #1 Newsgroup Service in the World! 120,000+
Newsgroups
----= East and West-Coast Server Farms - Total Privacy via Encryption =----
Its not unlikely. I dont know how this works but I detect two BBSIDs. If i
could attach a pic I would.
Seansan
>>Hi there,
> hardware.
>>I.e. when I connect
> default ssid.
>>I want my
>>can
>>do this (forced)?
> settings.
> Mark McIntyre
> News==----
> Newsgroups
> Seansan
>>>Hi there,
>> hardware.
>>>I.e. when I connect
>> default ssid.
>>>I want my
>>>can
>>>do this (forced)?
>> settings.
>> Mark McIntyre
>> News==----
>> Newsgroups
Nobody is arguing that you see two BSSIDs.  They're only questioning whether
they both come from the same device.  First of all, please post the BSSIDs.
Since, as Airhead stated, they are really MAC addresses, we can use that
information to discover the manufacturers of the devices.  If we discover
that they have different manufacturers, then we can be sure that they are
different devices.  The first half of the MAC address is the
Organizationally Unique Identifier, and can be looked up at
http://standards.ieee.org/regauth/oui/index.shtml .
I ran into one person who didn't realize she was running two Access Points.
One, she knew, was built into her wireless router.  The other was built into
her 2Wire DSL modem.  They were located in the same room, and running on the
same channel.  Downloads ran in fits and starts.  It's a wonder they ran at
all.
Ron Bandes, CCNP, CTT+, etc.
On Sun, 9 Jan 2005 23:04:48 +0100, in alt.internet.wireless , "Seansan"
And I detect about 4 in my front room. That doesn't mean my router has 4
different wireless devices in it. More likely there's other wireless access
points within range.
Mark McIntyre
Newsgroups
"Seansan"  wrote in message
> Hi there,
connect
Sounds like your neighbor has a network using the same SSID as you.
BBSIDs
are actually the router/ap Mac address. So a router having 2 of them
would be
unlikely unless it has multiple wireless adapters.
One of the
automatically
my
way I can
> do this (forced)?
You might try setting it up as the Preferred Network in the wireless
properties.
Once connected stop the windows WZC utility. From a command prompt
type services.msc find wzc and stop it. To reconnect you will probably
have to enable it
again. There are some methods to automated this process, search  "wzc
stop icon" or so.
Or get you a new router that has only one BBSID
> thx, in advanced
> Seansan
Site Timeline
