Hi all.
PREABLE
Having had a nightmare with wireless and an Edimax Access point (don't buy an Edimax AP! EW-7203APg) I took it back, an bought myself the PC Pro Recommended Kcorp 575 gold.
Well what a difference, you tell it you want WPA and it to work, and it just did :)
It is worth pointing out, I'm still using the Edimax Client Cards, a EW-7108PCg For the laptop, and EW-7128g For the 2 desktops.
As the title suggests, I'm having a problem with the available bandwith.
THE POINT OF THE POST
If I look at a bandwidth monitor, like the one in Kerio Personal Firwall (its just a line chart that tells you the ins and outs), regardless of where information is coming from (internet, other Wireless, or a wired computer) at precise intervals, which vary between 30 to 60 seconds, Incoming/outgoing packets drops to ZERO, nothing at all, for just under a second.
When downloading files, I can cope with this, when playing Battlefield 2, OH NO, it says 'problem with connection' every time, so that's every 40 or 60 seconds, depending what mood its in. this is unacceptable.
What can I do to correct the problem? Do you think its worth me buying a Kcorp client card just for my gaming PC?
THANKS
Thanks in advance to any suggestions, I will let you know how I get on.
Adam
