I've been having connectivity problems for months and it's driving me berserk!
Situation: I have a home networking package consisting of 1 modem, 1 Linksys Wireless B router, a destop and a laptop. My internet connection is perfectly fine, if I run the cable from my modem directly to either my desktop or laptop, I connect fine 24/7 with no issues. But when I run the connection through the wireless router, I have frequent dropped connections throughout the day. Sometimes I get lucky and the connection holds for a full day without dropping, sometimes it drops literally every 20 minutes. Here is the weird part, if the connection drops, I unplug the cable going from the modem to the wireless router and plug it directly into my laptop so that the laptop is connected to the modem, and then verify that there's a connection from my modem, there always is. I then plug the cable back into the wireless router, and then the wireless connection is somehow "reset" and works again(until it drops again in another hour of course). Now if I simply unplug the line from the router wihtout plugging it into my laptop and then plug it back into the router(I wait a few minutes between replugging), the connection will NOT re-establish. It will ONLY re-establish if I first connect it to my computer. I am absolutely baffled as to what is causing this problem.
I have the router's setting to get an IP address automatically, I'm using WPA for security.
And in addition, I had bought a Netgear router thinking something was just wrong with the router, but I had the IDENTICAL same problem but even MORE frequent disconnections. So I took it back to the store.
I don't know what the heck to do anymore. I'm hoping someone has some pointers! Help!
