In general are should there be any difficulties with using 802.11g NIC with 802.11b router?
- posted
16 years ago
On 11 Apr 2007 12:52:04 -0700, "Eugene F." wrote in :
Not unless you configured the wireless adapter for "g" only.
Generally, no. I think most public hotspots are "b" routers.
I did have a problem with a "b Turbo" card and a G router. I think the problem was a pre-release spec of one vendor's "Turbo" colliding with the PBCC code in a different vendor's newer "g" router.
I suppose that could happen in reverse, if you had an older "turbo" router.
