Hello
I've got my hands on a couple of Avaya AP's. And now I would like to make a wireless links bewteen the two points, to connect two buildings.
According to the manual and documentation, it should be possible to connect them with WDS.
And so I've configured WDS on both AP's with their respective wireless MAC addresses typed in in the oppisite AP, and enabled Spanning tree and enabled WDS security with a WEP 128bit key, same key on both APs. I have one DHCP server, on one side, and it should be that server that gives IP's to all the computers...
No matter what, I'm unable to ping the remote AP's management Ip, wich is in the same segment as the local AP.
Are there anyone who has tried to make a link, and possible could show me a configuration sample ?
Kind Regards Jacob
