My 802.11g wireless connection won't authentication with the AP if the signal and quality levels are below 40%. Yet once it's authenticated it will work at any level. In practice this means I have to move the laptop into the same room as the AP to get it communicating and only then can I use it in other rooms around the house. The AP and PC card are both Linksys 54GS. Is this normal ?
- posted
19 years ago
