Are some wifi ADSL modem routers not compatible with australian broadband services???
Threaded View
I've moved from the UK to Australia Oz and tried to use my Toshiba WBG
1200A ADSL modem/wireless router to connect to a local ISP called Optus
but i can't get it to work - the tech help at Optus suggest that it may
be because the WBG ADSL modem does not work in australia due to
different ADSL technical standards
- is this true???
i find this hard to believe although I've tried every permutation of
modem settings possible and have the correct VCI (8) and VPI (35)
numbers. I've even seen the same model sold on the expansys australian
website.
my connection method is pppoe llc and the connection works fine with
the non-wifi adsl modem supplied by optus -its just that i can't get
the toshiba wifi router/adsl modem to work - although I know for sure
that the toshiba works because it was working in England just before I
arrived in Oz, and it is working perfectly as wifi router because i'm
using it to transfer files via wifi between my 2 computers at home
I have the latest firmware version.
the configuration settings I've tried are:
1. Mode: PPPoE router, I've also tried PPPoA router
2. IP address = dynamic
3.DNS:
Enable DNS relay = I've tried OFF and ON (when ON, I used the DNS
server address 211.29.132.12 from the optus website)
4.PPP:
i've used correct password/user name which works with the supplied adsl
modem
5.ADSL:
VPI = 8
VCI = 35
Multiplexing = LLC Encapsulation Route, I've also tried LLC
Encapsulation Bridge, and VC based route, and VC based bridge
ADSL mode = G.DMT, I've also tried Mulitmode
6. Wireless LAN
Newtork name = WBG_Network
Those are all the options available in the simple configuration!
I don't know what the section called "Routing Information
Configuration" means - there are 2 options in it
1. Static Routing Ex: Network Address, Subnet MAsk, GateAddress 9,
Cost]; followed by a blank text box,
and
2. "Obtain Routing infromation INTO Wireless Braodband Gateway"
followed by the choice of 2 empty tick boxes saying Ver.1 or Ver.2
2. "Obtain Routing infromation OUT FROM Wireless Braodband Gateway"
does anyone know why some wireless routers/modems would work with optus
whilst others don't?
Any suggestions??
Thanks
Re: Are some wifi ADSL modem routers not compatible with australian broadband services???
BTW what is BigPond Cable that is used in Australia?  I will assume it is
similar to the cable here and it is not what you have.
Nothing strange with Windows XP's firewall?????  That is if you are running
XP.
Do you need to adjust your MTU to a different setting, or your WAN settings
down to 10Mbps?
read here about the subnet mask too:
http://www.freedom2support.net/forums/newreply.php?do=newreply&p=15383
or is that you  too?
Can you get your router to connect to your modem?  Can you plug up your into
one of the non-WAN ports of the router and see what happens when you try to
"dial-up" or connect to your ISP with the non-wifi modem?
I had one Speedstream ADSL modem/router where I had to change some of the
telephone wires around in the plug.
Newbie asking some ideas while trying to learn more.  <g>
later,
dave
USA
> - is this true???
> website.
> 3.DNS:
> 4.PPP:
> modem
> 5.ADSL:
> VPI = 8
> VCI = 35
> 6. Wireless LAN
> and
> Any suggestions??
> Thanks
i think bigpond is the name of the ISP run by Telstra - a big
Australian telecom company - its not what i have anyway
thanks for the link - no it wasn't me although I didn't understand a
lot of the advice given there
thanks
Site Timeline
