~ > ~ I believe the Cisco Aironet's can now be configured to use a local ~ > ~ database to do this authentication. ~ > ~ ~ > ~ Chris ~ > ~ > Aironet APs can be configured with a local RADIUS server, but they only ~ > support LEAP and EAP-FAST, not PEAP, which is what the o.p. was ~ > looking for. ~ ~ To clarify do you mean they won't do PEAP when going to a local radius ~ server?
Correct, the local RADIUS server feature in the AP does not support PEAP.
~ I ask because I worked with an 1130AG that was using PEAP mschapv2 ~ auth several months ago, but I think it was authing against a remote ~ server, not local.
Must have been.
Aaron
