AP in bridge mode don't act as WAP...
Hi, I had setup a wireless bridge beetween a remote router and an access point, where I can connect my PC using an ethernet cable. Now I want to access Internet from my PC without using the ethernet cable, but wireless. I know that in bridge mode, the access point do not act as a WAP... can anyone help me? I already tried connecting another access point to the AP in my home, but it doesn't work!
Thanks,
Claudio
Claudio Zanetta
Try setting your router up as a repeater instead of a bridge.
NetSteady
I didn't find this option in my router, I only have a WDS option and using this it works fine, but too slow, instead in bridge mode it works very fast, but I can't connect my pc using wireless. Do you have any idea why adding another AP it doesn't work?
Claudio
Claudio Zanetta
Have you tried using a "crossed" cable or a hub/switch?
Axel Hammerschmidt
A crossed cable, I can ping my AP but Internet doesn't work.
Claudio
Claudio Zanetta
Does the AP you can ping have its DHCP server turned on?
Axel Hammerschmidt
I think that one would of expected that as it is repeating information. I would also imagine it might be 50% or more slower.
David
No, all static ip.
Claudio
"Axel Hammerschmidt" ha scritto nel messaggio news:1hs94so.1xtjzli64bf2gN% snipped-for-privacy@hotmail.com...
Claudio Zanetta
On Fri, 19 Jan 2007 21:57:39 GMT, "Claudio Zanetta" wrote in :
That should work if connected and configured correctly:
+----------+ +----------+ | Wireless | | Wireless | ......... Ethernet +--------+ Access ......... | Bridge | CAT5 | Point | +----------+ +----------+
John Navas
