I have spent several hours trying to get a Linksys WRE54G to work with WEP enabled. I have a WRT54G router. Following the Linksys install instructions I disable encryption in the router and plug in the WRE54G. I press the auto-install button and it installs. Everything seems to be working fine. When I enable WEP either first in the WRE54G or first in the router, the red light goes on on the WRE54G which appears to mean it is not installed. Has anyone gotten this to work?
- posted
19 years ago
