Is it possible to have a wireless connection between the wireless card in your PC and the antenna? I bought a 7db antenna for the card that works great but I would like to be able to place the antenna anywhere I want without having a long cable going to it. Mostly for testing to see where it does the best as it seems to make a difference. Thanks
- posted
16 years ago
