My computer sits on the floor under the desk. The signal from the PCI adapter antenna is blocked by the computer in the direction it needs to see the wireless router. If I turn the computer sideways the signal strength comes up to an acceptable level. Does anyone know of a magnet mount antenna that can be used on top of the computer case or on the desktop?
Thanks, GC
